First post, by JerryG20
Okay, I'm trying to re-play some dos games (Tyrian and One Must Fall 2097) on my Vista PC. The problem is that I have a widescreen monitor, so these 2 games are stretched all the way and look horrible (I cannot change it to 4:3 and have black bars on the side with my monitor -- Westinghouse LCM-22w2). I read that you're supposed to edit the config file and change the following options:
aspect=false
to
aspect=true
And I believe this is supposed to give me the actual 4:3 original resolution with black bars on the side.
HOWEVER, Vista doesn't recognize the .conf file. I can open it with notepad, yes, but then when I go to save it doesn't let me save as a .conf file. What can I do to edit the .conf file without changing its file type?
EDIT: I was able to save it as a .conf file when I moved it outside of Program Files and onto my Desktop, and then moved it back. I made the "aspect=true" change, but unfortunately this did nothing. The display is still stretched (and sometimes the colors are all messed up; I usually have to alt-enter to window, and go back to full screen for the correct colors to appear).
