FAQ: Keyboard and vista
First post, by dalek
I want to run dosbox because I have this dos program (rkom) that works fine under up to xp but will not work in vista. So, what I plan on doing is booting dosbox, install XP, and then do what I have to do.
One main problem I had was that I could not edit the keyboard map under dosbox. Is this a Vista or dosbox issue? In any case, as a result I do not have, say, "\." I know there was a command line that should let me do it, but I do not see how I edit it and make it stick. Or, is there a way to make it just act like it has a normal (101?) keyboard?
Reply 1 of 2, by wd
Rank DOSBox Author
DOSBox Author
dosbox version?
Reply 2 of 2, by ADDiCT
I'm pretty sure this is a typo, but in case it isn't: you can't install XP in DOSBox (yet). (;
