First post, by Imwithstupid
Like the title says, the .dosboxrc file seems to be getting ignored, and even when I specify it with -conf the settings don't happen. Fullscreen is wrong and the screen is out of whack. The resolution I try to specify doesn't take. Any help?
Reply 1 of 10, by Qbix
Rank DOSBox Author
DOSBox Author
"seems to be getting ignored" is vague.
start dosbox from a console and it will tell which configfile it uses (or if it doesn't use one it will you as well)
Water flows down the stream
Reply 2 of 10, by Imwithstupid
What I mean is that the settings aren't working.
CONFIG:Loading primary settings from config file /home/soutai/.dosboxrc
the console says it's loaded, but nothing happens
fullscreen=true
scaler=normal2x
aspect=true
fullresolution=640x480
This are the contents, is this not correct form?
It doesn't start in fullscreen and going in manually puts the screen into 640x350, according to the monitor controls. And everything is out of whack, clipped viewing area, offset.
Reply 3 of 10, by TeaRex
You need the section names, otherwise it won't work.
Create a config file by saying at the Z:\> prompt:
config -writeconf .dosboxrc
Then quit dosbox and edit the file with a text editor.
tearex
Reply 4 of 10, by Taskr36
I tried creating a config file using the code config -writeconf .dosboxrc and no file was created. I tried again, but this time wrote it as config -writeconf glen.dosboxrc. It created the file and I edited it with my preferences. Unfortunately, DOSbox is not loading the file when I start it. If I start it from the Konsole I get:
CONFIG: Loading settings from config file /home/Glen/.dosboxrc
Where did I go wrong?
Thanks
Reply 6 of 10, by TeaRex
Put something like this into your .bashrc or .profile:
alias ll='ls -l -N -A -F --show-control-chars'
And then use ll instead of ls.
(edit: typos)
tearex
Reply 7 of 10, by Taskr36
That is just bizzare. How can such a file be opened if it is not displayed? What I've done is edit the second config file I made and just made a copy with the name .doboxrc and agreed to overwrite. It works, but I'd rather just be able to open and modify .doxboxrc. In case you haven't noticed, I'm still a bit of a noob with linux. Thanks for the help so far.
Reply 8 of 10, by wd
Rank DOSBox Author
DOSBox Author
Well those . files (.dosboxrc) behave like files under dos with the hidden flag set,
that is you can't list them with the default dir (dos) or ls (*nix) because, well,
they are hidden.
Reply 10 of 10, by MiniMax
Rank Moderator
Moderator
Well... Can you grab a cookie from a cookie-jar even if you don't look inside the jar and see the cookie?
_________________
