First post, by Spots
Hi,
I've known about Dosbox for some time now, used it to play Death Rally.
Having very nice experiences with it I installed it on 2 laptops. IBM T20 and T21
CPU: Pentium 3 700Mhz
OS Win2000 (they are used at work, 🤣)
HDD: both 18GB lappy hdd's
One has dual boot with 98, but that OS is fooked (reason I'm using Dosbox)
Both HDD's formatted as NTFS (dunno if this makes any diff)
On the faulty dual-boot lappy I installed Dosbox and it's running sweet. Even managed to get serial comms to work.
On the other lappy I also installed Dosbox, but it says c:/d: drive doen't exist, re-installed, installed on another location, still same message.
Only other difference is the working one is installed using local admin on normal domain.
Not working one was installed with local admin ActiveDirectory domain. (suspect this might be a problem, policies and that)
So my question comes to this:
Is this a known problem and is there any way to fix this?
Thnx for reading
Spots
Reply 2 of 5, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Please tell us exactly what you are typing in Dosbox and exactly what it says when the error occurs.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 3 of 5, by Spots
ok now I feel embarrased, it seems it won't work when you try: mount c c:
I remember reading somewhere it needs to be a directory you want to mount, not the root.
So basically this problem, if there ever was any, is solved.......
anyway, thnx for reading........and dosbox still rocks....😉
Reply 4 of 5, by wd
Rank DOSBox Author
DOSBox Author
If you really *want* to mount the root (which is NOT recommended,
and it's your problem if something goes wrong) you can use
"mount c c:\"
By all means you should avoid this and put your stuff into a subdirectory,
like c:\oldstuff and mount that.
Reply 5 of 5, by eL_PuSHeR
Rank Moderator
Moderator
You forgot to add the backslash character (\). That's why it wasn't working for you. Anyway, do as suggested and mount an specific folder (not the root) as drive c.
Just create a folder named oldgames, dosgames or something short like that and mount it as your C drive.
e.g. mount c c:\dosgames -freesize 700
That would mount c:\oldgames as drive C with 700MB of free space.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
