First post, by Gargle
Hello,
I have noticed that with the various versions of DOSBox I have tried (0.70 - 0.72), the CTRL+F12 key combination (for increasing CPU cycles) occasionally stops working. It won't work again until I have logged out of Windows and logged in again. Weird indeed.
I have no idea as to what could be causing this, but I figured maybe other people have this problem as well. Maybe it's a bug.
I am using Windows XP SP2 and a Logitech "UltraX Media" USB keyboard. I have no other programs running that capture keyboard input.
(It may be worth pointing out that my Logitech USB mouse doesn't work properly in specific combination with Daggerfall, either. The keyboard thing applies to all games and apps, even just the DOS prompt.)
Cheers,
Garg
Reply 5 of 8, by ErikGG
Or easier, open notepad and press CTRL-F4. This should close Notepad, If not then you have a broken key on your keyboard.
Could also F12 that is broken as you say the other combinations CTRL-F11 are working.
To test this open MSWord and press CTRL-F12 then the Open Dialog should be shown. If not the F12 key is broken.
Erik
Read the new FAQ.doc
Reply 6 of 8, by Gargle
I apologize for the ambiguity of my posts above. I tested the keys and their possible combinations in other apps, of course, and they worked. That's what I meant to say when I wrote they were fine.
I understand you guys get a lot of dumb questions on these forums and I appreciate your effort (I am very grateful for DOSBox), but there was no need to get snarky. I just wanted to report a possible bug.
Garg
Reply 7 of 8, by wd
Rank DOSBox Author
DOSBox Author
Nobody said it was a dumb question. And, as already posted, next time it
happens press the state-changing keys (alt/shift/ctrl and the lock keys)
a few times and see if the effect vanishes.
