First post, by SpeechMan
I have a big problem. Everytime resolution changes while in fullscreen mode, I get CTD without error message. If I try to switch away from fullscreen I get a "dosbox.exe has encountered an error and needs to close". Anyone got a clue what may be causing this?
Specs are as follow:
Q6600
8800GTS 320mb (162.18 drivers)
2Gig 1066Mhz CL4
Win XP Pro x64
I know this may be cause the display drivers, but I hope not, cause I can't change to the beta drivers.
Reply 1 of 5, by DosFreak
You specify 0.72. Is the behavior different in other versions of DosBox?
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
