First post, by Zarn
I am trying to modify (correctify...) xCom music. I used the OPL commands option, and the result is usable.
I now need to convert that to midi inorder to manipulate instruments.
I found here (and only here) a proggy called dro2midi, but when I tried it issued an erroe message "This song uses multiple OPL chips - this isn't yet supported!" and quits 🙁
Someone suggested to recompile it, alas this is way above my knowhow. Would someone please lend a hand?
    geoscape_000.dro.rar
    74.22 KiB
    384 downloads
Reply 3 of 5, by bugs_bugger
So there shouldn't be multiple opls. Have you tried modifying the sb entry in dosbox.conf? Maybe the game recognizes two opls and uses them for stereo. Also the error description could not apply, who knows.
Reply 4 of 5, by Zarn
That's an interesting idea! Problem is I know absolutely nothing about that stuff. Here is the SB section from my dosbox.conf:
sbtype=sb16
sbbase=220
irq=7
dma=1
hdma=5
mixer=true
oplmode=auto
oplrate=22050
The oplmode parameter accepts "auto,cms,opl2,dualopl2,opl3" Any idea what I should use? Worst case I'll try them one by one... only 4 options available.
