First post, by psynox
Hello there,
My last post about LPT ports i got some very usefull help, thanks for that.
This time, everything seems to be running nicly except network drives.
Im useing a few bits of software, mainly "VISI Cad".
When you go to call up a new dwaring or try to import a file, it hangs for up to 20 seconds while it reads whats in the folder.
Once i go into it, i can flick around the C:\ drive pritty fast but any network drives tend to be slower. (And the ones with meny files in are very slow)
Below is my config :
fullscreen=true
fulldouble=true
fullresolution=original
windowresolution=original
output=surface
autolock=true
sensitivity=100
waitonerror=true
priority=higher,normal
mapperfile=mapper.txt
usescancodes=true
[dosbox]
language=
machine=vga
captures=capture
memsize=63
[render]
frameskip=0
aspect=false
scaler=normal2x
[cpu]
core=auto
cycles=max
cycleup=500
cycledown=20
[vga]
svgachipset=s3
videoram=2048
[mixer]
nosound=true
rate=22050
blocksize=2048
prebuffer=10
[midi]
mpu401=intelligent
device=default
config=
[sblaster]
sbtype=none
sbbase=220
irq=7
dma=1
hdma=5
mixer=true
oplmode=auto
oplrate=22050
[gus]
gus=false
gusrate=22050
gusbase=240
irq1=5
irq2=5
dma1=3
dma2=3
ultradir=C:\ULTRASND
[speaker]
pcspeaker=false
pcrate=22050
tandy=auto
tandyrate=22050
disney=false
[joystick]
joysticktype=auto
timed=true
autofire=false
swap34=false
buttonwrap=true
[serial]
serial1=dummy
serial2=dummy
serial3=disabled
serial4=disabled
[parallel]
parallel1=reallpt
parallel2=disabled
parallel3=disabled
[dos]
xms=true
ems=true
umb=true
keyboardlayout=none
[ipx]
ipx=true
[autoexec]
[Custom CAD Start Lines]
mount E E:\
mount G G:\
mount H H:\
mount K K:\
mount C C:\
C:\
VISICAD.BAT
(I have removed hashed lines to make this post slightly smaller)
Could anybody shed some light on this problem?
(Machine is high spec by the way. 5200+ Dual core / 2GB ram etc)
E G H K are all network drives on the file server.
Thanks,
Aidan
