First post, by kalifax
is there is any way that i can use the DosBox for Sound blaster emulation while running in dos environment? plz help me
no
what about another sound blaster emulation software for dos? do such software exists?
The question is absurd. If your sound hardware has DOS drivers, it will probably already be useable as a Sound Blaster card by DOS applications. If your sound hardware does not have DOS drivers, separate "Sound Blaster emulation" would be useless.
i have this game called crusader no regret and an avanche logic als4000 sound card and i have both windows and dos driver for it too. my problem is that the game dont have sound thats why i want this sb emulator
If the soundcard has dos drivers then it will be Soundblaster compatible. The Crusader installer has an autodetect option which should work out. (of course you must have installed your drivers and have whatever program that driver needs to be running, running).
Alternatively Crusader works in Dosbox.
ive done numerous tests for my sound card and no matter what number that i set its port/dma/irq to except for one or two number that would cause error, it all worked just fine. but when it comes to the game setup, no sound ever produced. well i guess that cant be helped though. anyway thanks for the replies 😀
