The Dig
First post, by krony
Sorry if this pisses anybody off with the naivety of it, but I can't follow the ReadMe (hell, I could barely even find it) and I can't figure out how to even install The Dig, let alone play it on Vista. Seems like it needs to be installed first, but I can't even get past that part.
Reply 2 of 8, by wd
Rank DOSBox Author
DOSBox Author
Works fine in dosbox, too.
Look at the guides forum, there are step-by-step explanations.
Basically mount some directory as your c: drive, then your real
cdrom as d: drive, then install the game within dosbox.
Reply 3 of 8, by MiniMax
Rank Moderator
Moderator
60 Seconds Guide to DOSBox.
If that doesn't help, come back with details on how you mounted your C and D drives, how you did the install, how you configured sound, music etc.
_________________
Reply 6 of 8, by MiniMax
Rank Moderator
Moderator
And that forum would be??
_________________
Reply 8 of 8, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
The Dosbox game forum would be ok, but not really necessary since it has been solved. The topic was about a game with Dosbox, that it later became a "scummvm works fine, thank you" is just collateral damage 😀
So everyone stop spamming a solved thread 😀
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
