First post, by meelmark
Hi.
Using dosbox right now with a front-end, works nice! Using front end DFendReloaded.
I have a question; i have a 20 inch TFT monitor with original 4:3 ratio i though. Anyway, full screen gaming is very good.
But sometimes i wish i could set up a full screen, with the original resolution, say 320*200 or 640*480, as a stamp in the screen. So black borders around, and original 1:1 pixel map. Is this possible?
Reply 1 of 2, by Kippesoep
Use the "surface" output mode and disable scalers as well aspect ratio correction.
My site: Ramblings on mostly tech stuff.
Reply 2 of 2, by meelmark
great! solved!
