First post, by Eric Weir
- Newbie
I posted on this on the application-specific forum and didn't get a response, so I thought I'd try here.
I run an old DOS application -- a text procesor/outliner -- in DOSbox on Xubuntu and in a DOS window on Windows XP. In both installations the application is set to use CR/LF as the newline indicator. When I import documents created with the XP installation into the Xubuntu installation, CR/LF has no effect. Characters appear on one long string with no line breaks.
This doesn't happen when I go from Xubuntu to XP. Also it didn't happen in an earlier set up just like this one between an Ubuntu system and Windows 98SE system.
If anybody could clue me in on what's going on an how I can remedy it, I'd greatly appreciate it.
Sincerely,
Eric Weir
Xubuntu 8.04
