Running A Game?
First post, by pz3shwks
I am trying to play Time Commando. Using the wiki guide, i have mounted the game folder, and changed Z:\ to C:\. When i try the next step, CD TimeCom, it says it is unable to change the directory. Can someone help me out?
Reply 1 of 11, by pz3shwks
actually i think i got it. I hit MD TimeCom then tried CD TimeCom. Now it reads: C:\TimeCom>
But i have a new problem. Inside the folder there are 2 application programs "Install" and "Setup" both do the same thing, they bring me to Time Commando's Menu, where i can hit Play or Install/uninstall. Hitting "play" doesn't do anything.
When i try to activate anything within the TimeCom folder nothing happens. (I am using DOSBox 0.72)
There is a readme that says "AutoRun" with a bunch of commands, but none of them work in DOSBox:
[autorun]
open=setup.exe
icon=timeco.ico
shell\verb0\command=setup.exe INSTALL
shell\verb0=&Install
shell\verb1\command=setup.exe UNINSTALL
shell\verb1=&Uninstall
shell\verb2\command=setup.exe PLAY
shell\verb2=&Play
shell\verb3\command=notepad.exe read.me
shell\verb3=&Read Docs
Reply 5 of 11, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
buy the game and it will work. Downloading games is not legal unless the publisher allows it, and we can't help you with downloaded games.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 8 of 11, by general_vagueness
You know, most people don't understand the differences between downloading, uploading, and just plain loading.
You cannot fall off the floor.
If you look hard enough, you'll find something you don't like.
How to ask questions the smart way
How to become a hacker
How to answer smart-alec questions
Reply 10 of 11, by general_vagueness
<rimshot>ba-dum-tch</rimshot>
Reply 11 of 11, by MiniMax
Rank Moderator
Moderator
This thread has outlived its usefulness.
_________________
