First post, by Lassar
I have a dos program that uses screen mode 12h (640 by 480 4bit ,16 colors)
Do you know if the Mac DosBox version is capable of this screen resolution ?
The Mac is a MacBook with OS X 10.53 Leoard .
Has anyone with a MacBook played any games that used screen mode 12h ?
Does anyone have any experience, using the Mac DosBox ?
If you are; would you please check out this freeware program in DosBox.
Illinois Drivers Tutor
Conquer the FCC GROL, & Amatuer Radio test
Reply 1 of 1, by Qbix
Rank DOSBox Author
DOSBox Author
there are/should be no differences between the mac and the regular version of DOSBox, when it comes screenresolutions
Water flows down the stream
