First post, by drmdzh
I have read the FAQ all readmes.. nothing works.
All I'm trying to do is create/mount a C: drive to get this this working.
Using a Mac, intel core duo, 10.5.3
created a folder in my home folder names dos
in DOSbox typed
mount c/Users/username/dos
I get the message:
"Usage MOUNT Drive-Letter Local-Directory
So a MOUNT c c:\windows mounts windows directory as the c: drive"
It never works.
help please
Reply 2 of 8, by IIGS_User
wd wrote:
-> mount c /Users/username/dos (note the space) […]
(note the space)
mount c ~/dos
The tilde ~ marks your username folder and within DOSBox, press F6 ("Num") to aktivate the number block, now press the "alt" key and 1+2+6 in the number block to get the ~ within DOSBox. Finally, press F6 again to de-activate the number block.
And yes, note the space. 😉
Klimawandel.
Reply 3 of 8, by drmdzh
Cool, thanks that worked... guess my eyes are bad.
OK, next problem, the CD.
I switch to the C drive, then type:
mount d /Volumes/TIECD -t cdrom
I get:
MSCDEX: Mounted subdirectory: limited support.
Drive D is mounted as CDRom /Volumes/TIECD
I switch to the D: drive and nothing happens, how do I load the game?
thanks
Reply 7 of 8, by IIGS_User
drmdzh wrote:
mount d /Volumes/TIECD -t cdrom […]
I get:
Maybe add further parameters, like
-label TIECD
if the game expect the label name of the CD; or
-usecd 0
if you use a real cd.
Klimawandel.
