Sound on Ubuntu 8.04
First post, by DOS_Boy
I have recently installed Ubuntu 8.04 on my Core 2 Duo machine, and Dosbox right after. The thing is no matter what I do, I just can't get sound to work. Is there a official faq, guide or something that could help me set sound properly on Dosbox/Linux?
Processor: Core 2 Duo E6300
Sound Card: Sound Blaster X-fi Platinum
OS: Linux Ubuntu 8.04
Thank you.
"But listen to me brother, you just keep on walking, 'cause you and me and sister ain't got nothing to hide..." - Scatman John
Reply 1 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
start it from a terminal and watch what it tells you.
Water flows down the stream
Reply 2 of 6, by DOS_Boy
That's the error I got in the terminal screen.
Reply 3 of 6, by DOS_Boy
I know I might sound a little desperate, but can anyone at least give a clue on how to fix this issue?
Thanks.
Reply 4 of 6, by arrrgh
I'm not sure but maybe you should try reinstalling ALSA - it looks like it's broken.
Reply 5 of 6, by DOS_Boy
I was checking the ALSA project website, and it says there that the driver for X-fi cards is still a work in progress, as it's a relative new card. Does it affect me anyhow?
Reply 6 of 6, by ADDiCT
What do you want, a full tutorial on all variations and combination of PC and sound hardware, and Linux distributions (not to mention ALSA and kernel versions)? C'mon, if you're a Linux user, you're supposed to be a little more active. You could start with testing if your soundcard works OK with other applications. You should test digital output (playing MP3 or WAV files), and MIDI sound (playing a MIDI file).
PS: i'm no "active" Linux user, but i have enough experience to be pretty confident in saying that it's very likely for you to be pretty much scr*wed with new sound hardware, especially if it's from Creative. That company treats its customers like idiots, and i doubt they're cooperative towards the open source community.
