First post, by chynx
I´m a great fan of the old Hercules Graphics. (For nostalgic reason) I also like the afterglow effect of the old hercules screens.
I would like to have this effect in dosbox. Are there plans to increase the Hercules Graphics Mode?
If not I would check it out for implementation.
Reply 1 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
no plans, changes on getting it into dosbox aren't very high either if you decide to code.
Think that in the guilikoza directx pixelshader build there is an amber effect
Water flows down the stream
Reply 2 of 3, by chynx
All right. I will check out the code (shouldn´t be that difficult to add a second hgc option (color)) ...
Reply 3 of 3, by gulikoza
Both amber and green effects can be set with the shaders. Although I am not sure about the authenticity of the colors...
taiken7 also provided a shader that simulates the afterglow effect, but that one is somewhat broken since the output optimizations because the render loop does not run all the time...
http://www.si-gamer.net/gulikoza
