First post, by Smothermunchie
I'm running Dosbox on a Nokia N800 tablet.
It's about the equivalent to a 8-10 Mghz PC.
So I'm trying to push the limits to play text based rogue games with no sound.
What are all the options in the dosbox.conf file that I can turn off to boost the speed performance?
Like what all can I say 'none' or 'false' or set to zero and what should be set as 'yes' and 'no'. Also any other little tweaks besides cycles and frame skipping?
Really looking forward to hearing from someone on this.
Thanks!
