First post, by uncoolperson
I did some searching but didn't see anything, maybe i just didn't look hard enough, if that's the case I'm sorry.
Doom is locking up a bunch with multiplayer over a LAN using the ipxnet emulator.
Duke3D throws out some "out of sync" errors
Warcraft just freaks out.
I can usually get them going for a moment or two, we're thinking this is just one computer, but arn't sure as I can't find anything too wrong with that computer.
Any ideas?
Reply 1 of 5, by Sephiroth
I have used DOSBox to play via IPX, modem emulation, and null-modem emulation over the net to the other side of the country and not had a bit of problem with it. I'd check the system in question. Maybe it is running in half-duplex or something.
486 Launcher v2.0 is now under development!
Reply 2 of 5, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
cycles might be configured badly
1+1=10
Reply 3 of 5, by Sephiroth
True. For the games you mentioned, you can use a dynamic core with cycles set to max for the best performance on any machine. That is how I run those games, and they run flawlessly with those settings.
Reply 4 of 5, by uncoolperson
thanks everyone for your responses
I was using max cycles and auto core settings
I'll look into the duplex thing (once i figure it out...)
Thanks again
Reply 5 of 5, by Sephiroth
The automatic core fails miserably for most of my needs. Try a dynamic core with max cycles. I have the most success with that, and I can tell you that Duke3D, Doom, and WC2 run wonderfully on the dynamic core.
