Game runing errors.
First post, by MattM7117
When i mount my directory and install my files it seems to work but when i try to run the game it says cannot find installed files. I have tried installing them befor i run dos box, i have tried installing them in dos box, i have reienstalled it diddent work. The game is Caesar 2.
System
Vista home edition.
Just got dos box today.
is there somthing i can do to get is to work. if you need mor system info tell me and il try to get it.
Reply 1 of 6, by MiniMax
Rank Moderator
Moderator
Read my 60 Seconds Guide to DOSBox (and don't just read it - follow it too).
If that doesn't help, come back with details on how you mounted your C and D drives, how you did the install, how you configured sound, music etc.
_________________
Reply 2 of 6, by MattM7117
i used yours but il try agian im message in a couple of munnites
now im getting file creation failed in the status window.
Reply 3 of 6, by Sephiroth
Not sure what isn't being created, but run DOSBox as administrator.
486 Launcher v2.0 is now under development!
Reply 4 of 6, by MattM7117
same thing
Reply 5 of 6, by MiniMax
Rank Moderator
Moderator
_________________
