First post, by mobn
I'm trying to capture video, but it's simply not working. I'm using the most recent version on vista 32-bit if that matters. When I press ctrl-alt-f5 nothing happens. I even remapped video to the ` key, and still nothing happens.
The "captures" folder is empty (before you ask, I run as administrator and the program files folder is unprotected, UAC is off). In the config file I changed the captures folder to a different folder on another hard drive, and yet when I try to record, nothing appears there either. What could be going on?
