First post, by reaperofthelake
hello
i have been testing games with mouse like Harvester and i notice that the Y axis scroll works much slower than the X axis...
and if i add more sensitivity in the conf file (more than 100) its only affects the X axis!!
anyone knows the cause of this??? i cant play well because the mouse it feels weird like this 🙁 🙁 🙁
Reply 1 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
modify the sourcecode of dosbox 😉
I don't have harvester, but it might be relying on some default X/Y sensitivity being set with mode changes or not being reset.
Water flows down the stream
Reply 2 of 7, by reaperofthelake
mmm you are talking about a ''x/y'' sensitivity but in the conf file don't especifies two valors... only appears ''sensitivity=100''
Reply 3 of 7, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Another thread about this issue (mentions Constructor in particular, but the utility available there should work for other games as well):
Difference between horisontal and vertical mouse movement in Constructor
Reply 5 of 7, by reaperofthelake
i've tried mousex with 200 for the y axis but it seems don't change anything
snif snif... theres no solution? 🙁
Reply 6 of 7, by ripsaw8080
Rank DOSBox Author
DOSBox Author
It was reported to work with Constructor; might not with Harvester. Make sure you are running the main executable directly, e.g. MOUSEX 100 200 GAME.EXE
You can also try MOUSE2KV mentioned in the other thread.
