First post, by cywang23
I use DOSBox 0.72 in Vista 64bit, everything is fine. But I got a problem when I am using capture (ctrl-alt-f5).
I use some midi player in DOSBox and output MIDI signal to my external MIDI device (Roland MT-32), works very well. Then I connected my Roland MT-32 and my Creative X-Fi soundcard, I can hear the MT-32 sound from X-Fi.
I am sure that I choose the correct recording device and let it be default in Vista, because I use Windows Recorder or Adobe Audition both they can record the MT-32 sound from X-Fi.
Using ctrl-alt-f5 in DOSBox, only screen can be captured, but no sound.
Anyone can help me to fix the problem? thanks.
Reply 2 of 2, by MiniMax
Rank Moderator
Moderator
I have no idea if it is relevant at all, but check line 782 of the README:
"CTRL-ALT-F8 Start/Stop the recording of raw MIDI commands."
_________________
