First post, by wildweasel
I apologize if this is already documented in some obscure corner of the Wiki or readme files, but I'd like to know if it's possible to set up DOSBox so that I can resize its window like any other application without needing to modify the dosbox.conf file every time I want to change the size? Ideally I'd like to be able to just drag the window to a specific size and have DOSBox's output scaled to fit the window regardless of actual screen resolution.
Reply 1 of 3, by MiniMax
Rank Moderator
Moderator
Don't think it is possible.
_________________
Reply 2 of 3, by wildweasel
Would I be able to post this as a feature suggestion, then? Where would I go to do that? (For that matter, is DOSBox even being developed anymore?)
