mapper.txt missing
First post, by dbarton
I have the path to mapper.txt in my custom .conf file, but when I try to save it says:
can't open "c:\program files\dos-box\mapper.txt" for saving the mappings.
I created a blank mapper.txt as one didn't exist..
Any tips?
Reply 1 of 16, by hydr0x
You're probably using Vista. If so you don't have writing rights for the program files folder. Just move DOSBox to another folder like c:\tools\ and it should work.
Reply 2 of 16, by MiniMax
Rank Moderator
Moderator
Or he could change the configuration file and point the mapper file to a folder where he HAS writing rights.
_________________
Reply 3 of 16, by hydr0x
sure, but having DOSBox in a restricted path produces other problems as well, like when you want to use a frontend to edit the conf or anything like that
Reply 4 of 16, by MiniMax
Rank Moderator
Moderator
Corrent, but frontends usually make their own copies of the config file, so that should not be a problem.
_________________
Reply 5 of 16, by dbarton
No, im using XP.
This particualr .conf is in C:\spg
The mapper file is in the DOXbox folder.
Reply 6 of 16, by wd
Rank DOSBox Author
DOSBox Author
Obviously not in the default installation folder.
Reply 7 of 16, by MiniMax
Rank Moderator
Moderator
I don't think DOSBox is smart enough to load the config file from one folder, and the mapper.txt file from another. You will have to tell it exactly where that mapper.txt file is.
_________________
Reply 8 of 16, by dbarton
I'm not on that machine, but as I recall I put mapper.txt in c:\program files\dos-box\ which is the location DOS box autmatically installed to..
I created a blank mapper.txt there as one didn't exist.
Since I run my .conf file from c:\spg does my mapper file have to exist in c:\spg instead?
My conf file has the full path to the mapper file listed.
Reply 9 of 16, by MiniMax
Rank Moderator
Moderator
Your mapper file needs to be where the conf file says it is. It is that simple.
_________________
Reply 10 of 16, by dbarton
I think I have this all right, but still get that error msg.
I'm using a conf with this in it:
[sdl]
etc
etc
mapperfile="c:\Program Files\DOSbox-0.70\mapper.txt"
etc
etc
The mapper.txt file is there and is empty.
I'm confused. Doesn't this all look right?
Reply 11 of 16, by wd
Rank DOSBox Author
DOSBox Author
Why 0.70?
Reply 12 of 16, by dbarton
I'm using Don Wells patch for MIDI output (TESTMT32), and that is only in .70 as far as I know.
Reply 13 of 16, by MiniMax
Rank Moderator
Moderator
Looks okay. And you don't start DOSBox from some frontend? Do you see anything, any error messages, in the DOSBox console window? Try with 0.72 and see if it works there. Try moving the mapper file to some other location.
_________________
Reply 14 of 16, by dbarton
the error messgae is:
Reply 15 of 16, by MiniMax
Rank Moderator
Moderator
Isn't it strange that you write this in your config file:
and DOSBox complains about this:
_________________
Reply 16 of 16, by dbarton
One was wriiten from my memory when I wasnt in frotn of the machne...
The error message points to the real place..
