First post, by galiman
I've read quite a bit on the WIKI and the Forums, but have seen slightly conflicting information on exactly how configuration files work. I understand that you can create specific .conf files for different games, etc. Buy what I don't understand is how exactly this works. For example, one passage I read said that DOSBox processes both the default .conf file and any .conf file specified in a command line argument. This doesn't sound right, but is this the way it works?
Also, for user created .conf files, into what directory should they be placed? I'm assuming the DOSBox directory, but am not sure.
Thanks for any help.
