First post, by gmailtae
Here are some of the errors with ABCGRL.
If you type in at sign, the " will be appeared.
If you type in number sign, the £ will be appeared.
If you type in circumflex accent, the & will be appeared.
If you type in ampersand, the slash will be appeared.
If you type in asterisk, the opening parenthesis will appear.
If you type in the opening parenthesis, the closing parenthesis will appear.
The file arrow.cur was named arrow.cu_ and the file isn't working.
If you type in the closing parenthesis, the Equals sign is appeared.
If you type in the grave accent, the Reversed Solidus will be appeared.
If you type in the tilde, the Vertical Pipe will be appeared.
If you try unloading it, Program ABCGRL already loaded !. will be appeared.
Other errors.
Try typing in the left square bracket.
The plus sign appears.
Try typing in shift left square bracket.
The asterisk appears.
Try typing in the right square bracket.
The almost equal to symbol at ≈ will be appeared.
Try typing in shift right square bracket.
The circumflex accent was appeared.
Try typing in colon.
Grave accent was appeared.
Try typing in semicolon.
Single quote was appeared.
Try typing in 'less than'.
Semicolon was appeared.
Try typing in 'greater than'.
Colon was appeared.
Try typing in slash.
Hyphen was appeared.
Try typing in question mark.
Low line appears.
Try to uninstall the program with abcgrl /u.
It will give you the message: Program ABCGRL already loaded !.
Try to do the same as abcgrl /h.
Program ABCGRL already loaded !. was appeared. Can't give you the help.
Do the same.
Program ABCGRL already loaded !. is the message that appears.
You also notice the missing character Ϊ at U+03AA and Ϋ at U+03AB.
Try replace the loaded DOS Greek font with CLS.
The DOS emulator tried restored the font to default.
You already typed in the error. The error was Program ABCGRL already loaded !.
The Old DOS Font is created and you hate the old DOS font. You like the new DOS font. The letters like T, m, M, V, W, Y, Z, digit zero, Peseta, cent and Japanese yen were updated.
Try unloading it. Program ABCGRL already loaded !. will reappear.
Reply 2 of 16, by MiniMax
Rank Moderator
Moderator
It is strangely on topic (DOS, DOSBox, ABCGRL = probably some ABC (font) for GReek Language). I could imagine some strange results & characters with DOSBox and a Greek keyboard.
_________________
Reply 3 of 16, by wd
Rank DOSBox Author
DOSBox Author
If he's a bot, he's a very very clever one, though i'm still thinking it's some
regular user having a hard time to explain himself 😉 But no idea, do what
you want with that 😀
Reply 4 of 16, by DosFreak
The problem I have is there's no explanation in any of the posts. Just a list of things done.
It's like the person doesn't care if they are responded to or not.....they just post whatever it is they have done.
We are either dealing with a very young/old person and/or someone with a mental issue......or a bot.
I'll move it back.....it just irritates me.
Make your games work offline
Reply 5 of 16, by gmailtae
You aren't a moderator.
When you type in ABCGRL, it will show up the following text:
Greek Fonts and Keyboard Driver for PS/2.
Copyright (c) 1990 Tasos Lambrakis.sv1bee.
Copyright (c) 1990 ABC Systems & Software.
Version large-1.0
Γραμματοσειρά IBM - 437
Αλλαγή γραμματοσειρών με: [Alt] + [1] = 437
[Alt] + [2] = 851
[Alt] + [3] = Elot 928
Αλλαγή πληκτοσειρών με [Alt] + [Enter]
You already launched FontEdit 1.0. It's made by Michael J. Mefford. It's submitted to PC Magazine.
Try the same type with abcgrl /u.
Reply 6 of 16, by wd
Rank DOSBox Author
DOSBox Author
Are you using dosbox?
Reply 7 of 16, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Poster has also reported being unable to uninstall NovaFont: CPX Font editor
The Greek font TSR in question can be found at http://www.hyper.gr/greek-fonts.html
Just as with NovaFont, there is no evidence that the TSR can be unloaded with a command line switch. I think this poster is under the assumption that an uninstall option is usually available, but that's really not the case. It's actually kind of a pain to make a TSR that can uninstall itself, and restarting DOS (or DOSBox) is easy.
The Greek font TSR does seem to have some issue in DOSBox when changing the character sets with its hotkeys, but there's the complication of keyboard layouts and codepages, so hard to say if it's a problem. And when having to decode the poster's unusual English phrasing (You = I ?), it's also hard to be sure of the intended purpose of the thread.
Reply 8 of 16, by Leolo
Maybe you could challenge him to decipher one of those annoying CAPTCHAs that litter the internet. I specially hated the one about cats that was used by rapidshare!
Although, having failed a lot of them myself, I wouldn't be completely sure of the results 😊
Regards.
Reply 9 of 16, by gmailtae
You can now switch between character sets in the new versions.
Reply 10 of 16, by eL_PuSHeR
I am with DOSFreak. I think it's a spambot even if it is a very sophisticated one. Most of his/her/its post are meaningless.
If he/she isn't a bot then he/she has got plenty of time to learn the basics of English language. A lot of people here aren't native english speakers, including myself.
Reply 11 of 16, by gmailtae
Keyboard shortcuts for switching character sets:
Alt + One = Four hundred thirty seven
Alt + Two = Eight hundred fifty one
Alt + Three = Elot nine hundred twenty eight
Reply 12 of 16, by TeaRex
@gmailtae: Learn English! or get somebody to help you.
tearex
Reply 13 of 16, by gmailtae
You can see the Greeks on your post.
Reply 14 of 16, by keropi
Since I am greek and I can understand the greek instruction from the TSR:
Alt+Enter changes greek/english input
Alt+1 , Alt+2 and Alt+3 just change between fonts.
you must remember, that Greek keyboards back then did not really follow any standard, IBM machines had different layouts on their keyboards than Olliveti ones for example... so this could explain why "wrong" special characters appear. All those tsr's of the time where custom made for specific brands/models.
is that what you need to know?
🎵 🎧 MK1869, PCMIDI MPU , OrpheusII , Action Rewind , Megacard and 🎶GoldLib soundcard website
Reply 15 of 16, by gmailtae
The following shortcuts for Alt + One to tree will work for yourself with no problems.
Reply 16 of 16, by eL_PuSHeR
[Thread locked]
Gmailtae answers make no sense at all.
