First post, by Captain Shiny
I have severe problems installing the Gravis Ultrasound drivers in Dosbox 0.73.
It shows the following error:
"Install cannot determine the UltraSound card type installed.
This is usually caused by a base port conflict.
You should exit Install, remove the UltraSound Card and
Run CONSCAN.EXE on the first installation Disk."
Here's what I did.
1) I changed settings in the .conf to gus=true
2) I mounted the "Gravis" directory to C:\
3) I ran install.exe
I already checked those faqs:
http://www.angryflo.de/dosbox.htm#Ultrasound
http://www.dosgames.com/forum/about10574.html
Install Gravis Ultrasound Properly, All files, No Errors (With Pictures!)
And downloaded the Gravis drivers (v.411) here:
http://ftp.isu.edu.tw/pub/Hardware/multimedia/Gravis/gus411/
The installation process works fine under 0.72 and I have totally no idea why it doesn't work in 0.73. I use D-Fend-Reloaded v.0.81 so I can't simply downgrade to 0.72.
I also tested it with the standart releases of 0.72 and 0.73 without d-fend.
Any help would be appreciated.
