First post, by hawks1282
Hello all,
First of all, thank you to everyone who's worked on developing this application. It works wonderfully and I love being able to play the classic games so easily.
My question is this . . . When I enter full screen mode on my wide screen monitor, the screen is stretched so that it completely fills the screen from right to left, with black bars on the top and bottom. I would like to get it to either fill the entire screen, or maintain a 4:3 aspect ratio and stretch from top to bottom with black bars on the sides. I've tried changing the machine type, and also adjusting the full screen resolution settings, but haven't had any luck.
When playing with the full screen setting, I've found that many times if I enter certain sizes, when I go into full screen mode, the DOSBox screen rotates itself 90 degrees counter-clockwise. Is there any way to prevent this?
Thanks, Hawks
P.S. The issue that I'm having occurs when I'm in the command prompt of DOSBox and when I run the program I'm trying to use, but the program itself is not a game (legacy circuit design software) so if you don't want to spend the time discussing non-game software, please let me know and I'll try another forum (I definitely understand). I play the games on 4:3 monitors and all is well there 😀
