First post, by danielc
- Member
Heya guys
Well I fired up one of my old games, I can't get cd audio to work which previously worked fine. Nothing changed software wise but I did reinstall a newer build of Windows 7 - the DOSBox install and the game are the same. Something has broken CD audio in all DOSBox games I try, they just dont play anymore.
The BIN/CUE formatted files are correct, i'm using the right IMGMOUNT command. Copying the same DOSBox + game (Redneck Rampage Family Reuinion in this example) pack to another Windows XP machine works fine.
Is there a way I can turn on "verbose logging" or something for DOSBox 0.73? Maybe the MSCDEX output will help if I could see it? 😕
Thanks in advance for any help 😀
Regards,
CosmicDan
