Hallo, i think i have the same probleme but maybe you misunderstand it?
I use DosBox 0.73 at my Win XP System. To install older Dos Games i buy a USB Floppy. I installed it and now in Win its Drive A: So i mount it in DosBox as A A:\ -t floppy
But now i have a problem. If i start dosbox i get an error message. It says (in german) "There is no Disk in drive A:!" I can insert a disk and type dir and all works fine. But if ever i start dosbox i get this error message!
Is there any way to fix this? Is there a way to tell dosbox not trying do load the disk at start?
Maybe someone can help!
Thanks a lot!
Heiko
PS: If i do misunderstand the question please blame it at my bad english and excuse it 😀
