How to load CD-ROM driver?
First post, by Jusko
Hi.
I want to install Atlantis: The Lost Tales. Old game from Cryo. Atlantis can be run in DOS (i think). The is DOS install on CD1. When i try to run dosinnstal DosBox wants CR-ROM driver. What driver? 😢
It means: "No CD-ROM Driver". I'm using Linux and game working under Wine, but game runs too fast on modern PC 😢 How to load this CD-ROM drivers? I think mouse drivers will be needed too for this game.
Reply 2 of 46, by IIGS_User
Do you ever seen a CD-ROM installed as drive C: 😕
Klimawandel.
Reply 4 of 46, by gidierre
Atlantis The Lost Tales on Vista?
We often forgive those who bore us, but we cannot forgive those whom we bore. (La Rochefoucauld)
Reply 6 of 46, by Jusko
I installed game and game run, but not without mancaments (little slow and choppy sound sometimes). In Atlantis how-to the is:
3) Set: Core: Dynamic, Cycles:30.000+, mouse sensitivity 300+ and enable autolock mouse option.
How to do that?
Sorry for my little experience with DOS and DosBox, but i'm using Linux and his bash command-line many years, so my experience with DOS is small, but i used DOS to install Windows 98 from time to time 😀 When i click in DosBox window, mouse is grab by him. How to get back my mouse to work ouside DosBox window again? 😀
EDIT:
I found that capture and release mouse is Ctrl+F10 combination and i know now how to add more cycles. But how change mouse sensivity? Atlantis have terrible jerky sound - is there any way to fix this? 😢 Only mouse sensivity and this sound issue are problem. This sound makes this game almost unplayble, because there is no way to listen this - it's danger to ears 😢
Reply 7 of 46, by robertmo
dosbox configuration in start menu
Reply 8 of 46, by Jusko
I don't have start menu, because Im not using Windows and nothing from Windows OS family.
Reply 10 of 46, by Jusko
How i may forgot about config file in ~/.dosbox. THANKS. Shame that sound in Atlantis is broken 😢 😢 😢 Maybe DosBox 0.74 fix this...
Reply 12 of 46, by Jusko
Where i can report them?
Reply 14 of 46, by Jusko
Nothing. Where i can report sound bug in Antantis? It's one of my dreams to play once again this game. Game is playable (with mouse sensitive 500+), but this sound issue makes game unplayable for ours ears 😵
Reply 15 of 46, by robertmo
what have you tried?
Reply 16 of 46, by Jusko
Performance is OK. Mouse with more sensitive is...almost normal (little lag but playable). I have problem only with sound.
STEP 3 - Performance
Yay, you've gotten your game to run! But maybe you're experiencing slowdown? How do you fix this? With the following commands:
CTRL + F7 = Decreases frameskip
CTRL + F8 = Increases Frameskip
CTRL + F11 = Slows down the game
CTRL + F12 = Speeds up the game
Reply 17 of 46, by robertmo
tried fixed cycles?
Reply 18 of 46, by Jusko
I used core=dynamic and when i have active game i see cycles: max on upper DosBox window. Problem with sound is beyond cycles maybe. At least DosBox is not compatibile with ALL games. I must try fullscren - did you write about games in fullscreen are faster than in window? I read this somewhere on this forum.
Reply 19 of 46, by robertmo
try fixed cycles.
