First post, by sehh
- Newbie
I'm playing some fairly demanding games and demos. Unfortunately, most of these games have issues with the emulated SoundBlaster in dosbox.
For example, I try to play some pinball games, the audio has scratches and pops, but only when playing audio via the SoundBlaster. If I switch to the Gravis Ultrasound, then everything is ok.
Another example is the game "Eye of the Beholder 3". Audio has delays and various scratches, pops and other glitches.
The above only happen on some fairly demanding games (regardless of cpu usage), which use the SoundBlaster, but work fine when the Gravis Ultrasound is used.
Anyone got any suggestions? Is the SB emulation so bad that I should avoid it?
sehh
