First post, by phryas
Hi all, first time post....
Have dosbox (latest version - 0.73?) on windows xp. Have a competition pro usb joystick which is connected and calibrated fine in windows xp. When I run sensible world of soccer (sws) I can use the joystick fire to get past the title screen but can only use keyboard after this point. There is no config file so I copied one from dosbox 0.72 - when dosbox starts up it says it is using the joystick with 2 axis and 4 fire buttons, but I have no control.
Tried using d-fend but it cannot detect joystick when I run the setup (install.exe).
Any suggestions would be gratefully received!
Cheers
