First post, by sojourner
As the title states, dosbox status window will not close. I'm running an old calendar program. Dosbox runs well with the exact same setup on three other (different) computers, all with numerous OS's (XP, W2K). The computer it will not work properly on is an X60 IBM Thinkpad laptop, Intel graphics, Core2Duo.
I've tried Dosbox from v6-v73. Altered CONF. Turned off BIOS dual core features ... nothing works! The program runs fine but when the program exits the status window remains and must be forceably closed. Tried the standard Dosbox.conf and it to runs but upon exit the status window will not close. There are no error messages in the window.
Can someone help me getting it to work properly?
Thnx
