First post, by mrtech
Hi I am very new to Dos Box, I did use Dfend once and found that I could get quite a few dos games running good, others I had trouble with but most I could get working.
I never did this via the configuration file only Dfend, I would like to just use DosBox.
So now you know I am not very experienced at Dos Box but can use it.
I was wondering how would I go about setting up a game to run good on my computer but then being able to run good on my friends computer as well.
Can I do this without them or me having to reconfigure the settings?.
Also what is the difference between Dos Box and Dos Box Portable.
Thanks for all your help.
PS: is there a site that shows good settings to use for certain dos games?
Reply 1 of 1, by robertmo
1. Get the latest DOSBox from www.dosbox.com
2. Install it to C:\DOSBox-0.73\
3. Start dosbox and type:
config -writeconf dosbox.conf
(dosbox.conf appears in C:\DOSBox-0.73\ folder)
4. Quit dosbox
5. Make folder C:\DOSBox-073\VirtualHDD\
6. Edit C:\DOSBox-0.73\dosbox.conf
Under [autoexec] section type:
mount C .\VirtualHDD\
C:
Under [sdl] section change:
fullresolution=0x0
output=openglnb
Under [render] section change:
aspect=true
