First post, by Jokkey
I'm using DOSBox to run a legacy productivity app (and I realize that isn't quite DOSBox's intended purpose...), and one problem I've run into is that it often gets into a state where it seems to hang if its window is obscured by other windows.
Is there any way to start DOSBox in the background (i.e., not an active window) and make it continue processing even if it's not a foreground window?
