First post, by Question
I understand that you can press ctrl+f12 to increase CPU cycles.
My question is why isnt there a better way of doing this?
For example pressing it once only increases by like 5k cycles?
For games that run EXTREMELY slowly under dosbox, you would need to spam it dozens and dozens of times to get it to work properly.
Why not change it so that holding ctrl+f12 increases the cpu cycle constantly till you stop holding it down? Or allow us to edit a config file so that dosbox starts out at the same CPU cycle everytime? Rather than spamming ctlr+f12 100+ times everytime you want to play an old dos game....
