First post, by Nat
Hi everyone.
I've a tiny problem using the Dosbox. In every game I play, I've a little gap between the image and the sound. Is anyone know how to supress this gap ?
Thanks for your help.
Reply 1 of 12, by robertmo
what is your dosbox version and where have you got it from?
what is your Operating System?
what are your PC specifications?
what games have problems?
post content of "DOSBox Status Window"
enclose your dosbox's config file
Reply 2 of 12, by Nat
Dosbox version : 0.73 (I've download from the official website)
OS : Window Seven 32bits, but the same problem occurs on XP SP 2
PC specs : Intel Core 2 duo 2.38GHz, 3Go of RAM, nVidia GeForce 8400M GS
I've this problems on all the games I play : Archemidean Dynasty, Albion, The Settlers 2, Tyrian 2000, Jazz Jackrabbit, Syndicate wars, etc.
Content of DOSBox Status Window :
DOSBox version 0.73 Copyright 2002-2009 DOSBox Team, published under GNU GPL. --- CONFIG:Loading primary settings from config fi […]
DOSBox version 0.73
CONFIG:Loading primary settings from config file C:\Users\Nator\AppData\Local\DO
SBox\dosbox-0.73.conf
MIDI:Opened device:win32
DOS keyboard layout loaded with main language code FR for layout fr
    dosbox-0.73.conf
    9.95 KiB
    94 downloads
    Here is my .conf file
Reply 11 of 12, by Qbix
Rank DOSBox Author
DOSBox Author
thanks for testing it out.
44100 with 1024 is currently my favorite setup as well
Water flows down the stream
