First post, by wh1tefang94
I have been a user of dosbox for sometime now, and love it but recently i have been having a weird problem, everything i type has the last letter cutoff, for example I type Exit it reads it as exi, so now i would have to type exitt for it to read exit.
Reply 1 of 5, by robertmo
what is your dosbox version and where have you got it from?
what is your Operating System?
what are your PC specifications?
what games have problems?
post content of "DOSBox Status Window"
enclose your dosbox's config file
Reply 3 of 5, by wh1tefang94
My version is 0.73, I got it from the main site. This problem happens on everything in dos box, even outside of programs in general.
My Status Window
CONFIG:Loading primary settings from config file C:\Users\****\Appdata\Local\DOSBox-0.73.conf
Memory sizes above 31 MB are NOT recommended
Stick with the default values unless you are absolutely certain.
MIDI:Opened device:win32
MAPPER: Loading mapper settings from C:\Users\****\Appdata\Local\DOSBox\mapper.txt
SHELL:Redirect output to nul
The Batchfile autoexec refers to
:: Menu.bat
:: Mounts isos/cd
cls
echo press 1 to mount EarthWorm Jim 1&2
echo press 2 to mount Daggerfall CD
echo press 3 to mount CD Drive
@echo off
choice /c:123>nul
if errorlevel 3 goto CD
if errorlevel 2 goto DAG
if errorlevel 1 goto EWJ
:: CD ROM CHOICE SET START
:CD
mount d d:\ -t cdrom
GOTO CDC
:CDC
cls
echo press 1 to continue to dos
echo press 2 to start OS
@echo off
choice /c:12>nul
if errorlevel 2 goto START
if errorlevel 1 goto DOS
:DOS
mount c c:\dosgames
c:
cls
goto end
:: CD ROM CHOICE SET END
:: Earthworm Jim CHOICE SET START
:EWJ
cls
echo press 1 to Start EarthWorm Jim
echo press 2 to Start EarthWorm Jim 2
echo Press 3 to Start OS
@echo off
choice /c:123>nul
if errorlevel 3 goto DOSS
if errorlevel 2 goto EWJ2
if errorlevel 1 goto EWJ1
:DOSS
imgmount d c:\iso\EWJ1.cue c:\iso\EWJ2.cue -t iso
Show last 49 lines
GOTO START
:EWJ1
imgmount d c:\iso\EWJ1.cue -t iso
mount c c:\dosgames\games\ewj
c:
cls
ewj1
GOTO end
:EWJ2
imgmount d c:\iso\EWJ2.cue -t iso
c:
cls
ewj2
GOTO end
:: Earthworm Jim CHOICE SET END
:: DAGGERFALL CHOICE SET START
:DAG
mount d c:\dosgames\games\dfcd -t cdrom -label Daggerfall
cls
echo Press 1 to run DaggerFall
echo Press 2 to Start OS
choice /c:12>nul
if errorlevel 1 goto DAGS
:DAGS
mount c c:\dosgames
c:
cd dagger
dagger.exe
goto end
:START
mount c c:\dosgames
c:
cd nc
nc
:end
Sys specs:
Windows Vista Home Premium
NVIDIA GeForce 7900 GS (Two of them)
Intel Core 2 CPU
3.00 GB RAM
3.00 GB Total Physical MEM
1.37 GB Available Physical MEM
6.21 GB Total Virtual MEM
4.43 GB Available Virtual MEM
Quite Honestly I don't know what you want spec wise, if this isn't what you wanted I'm sorry.
    dosbox.conf.txt
    9.92 KiB
    148 downloads
