Font size
First post, by pasteque
Hi,
I use dosBox with Ubuntu.
In window mode, the défault font size is too small for me, because my screen resolution is 1440x900.
When I setup dosbox.conf : fullscreen=true, it works, but the display is fuzzy.
Is it possible to setup a window mode, but with a different font size or windows size?
I have try to setup "windowresolution" to another value than "original" (i.e. 800x600) but it seems not working.
Thanks for your help.
Reply 2 of 10, by pasteque
Thanks, windowresolution works fine when I setup output=opengl instead of output=surface
But, now, with a largest window, the display is fuzzy.
I suppose the cause is dosBox use a bitmap font ?...
How to set up a different font (i.e. courrier new, vectorial) instead of the default dosBox Font?
Thanks.
Reply 8 of 10, by ADDiCT
DOSBox outputs pixels, not characters like a "normal" terminal window. You could change fonts inside the emulation, though i'm not sure how this works. Tools like WBAT for example seem to use some kind of custom font.
