First post, by ilya-42
Hello there,
I've tried the "record video" feature with ctrl+alt+F5 and found it absolutely adorable. Everything worked like a charm and I got the video ready for sharing in my "Capture" folder. However, I ran into a problem wich caught me slightly off-balance.
The resolution of the resulted video was 320*200, that looks fine when you watch it at your own computer but youtube does not want to convert it to higher resolution since the res. is too low and the video it spits out after the conversion is way below average.
The question is mostly to those who had the same or similar problem. Is there a way to make a video of higher resolution using DosBox software or any possible work-around to this problem.
Thanks in advance.
