First post, by Fabiolinks
I downloaded DosBox 0.74 but when I open it the dosbox window close (about 1 second after) 😒
ps - I am using windowns 7
Thanks
DooM x Quake x Heretic
Reply 1 of 4, by TeaRex
Use better thread titles please. You might create a world wide shortage of exclamation marks otherwise, worsening the financial crisis. 😁
Post your PC configuration (CPU, Operating system, Graphics card mostly).
Do you use the latest drivers for your graphics card?
Where did you download DOSBox from?
What exactly (step by step) did you do to get it to run?
Is this the first time you tried to install DOSBox, or did you ever have an older version installed?
tearex
Reply 2 of 4, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
And adding to TeaRex' questions, dd you manage to install Dosbox or did the file you download crash?
If the downloaded file crashed, please download it again, your download might be incomplete or such.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 3 of 4, by DosFreak
Thanks
Go into DOSBox Options and change output= to a different value.
Make your games work offline
