First post, by truffaut
There are several threads concerning Alt-GR but no real answers. There is little information on the mapper.txt file.
Some of my problems (getting WORD 5.5 for DOS to run in a DOSBox in Windows7):
- Why do mod1 and mod2 have 2 keys attached?
- The mapper layout is always(?) US. If you select the right alt-key the corresponding event(?) is key_ralt (the notation may not be completely accurate because I don't have access to the dosbox right now). However, it appears impossible to assign that key to mod3. If I press the right Alt-key to assign it to mod3, the Ctrl key appears as as binding.
- The backslash on the German keyboard is the same key as ß/?. The entry in the mapper.txt file ist 'key_minus "key 045"'. If I want Ctrl-Alt+ß to map to a backslash, I would think that 'key_backslash "key 45 mod1 mod2"' should work. I managed to get such an entry by using the keymapper, but it didn't work.
- How does "keyb gr 437" or "keyb gr 858" affect the mappings in mapper.txt? Do the key numbers change?
Any helpful information will be appreciated.
François
P.S. At one point I had all Alt-GR combinations of the German keyboard available in the command line (like {[]}\|~@) but in WORD the Alt-GR key worked just as the Alt-key (to enter the menu)
