Dosbox Serial no:
First post, by boschwakka
I have a program that ran on windows 98 and dos and the license key looked at the hard drive serial number.
How can i set the serial number in dosbox.
I have tested the progeam and it runs but meeds a license key and the software is discontinued so i cannot get a new license key.
thanks mark
Reply 2 of 3, by ripsaw8080
Rank DOSBox Author
DOSBox Author
It depends on how the software reads the serial number. If it uses INT 21/440D, you can change the number that DOSBox reports from 1234-0000 to whatever you want. Look for "serial number" in dos_ioctl.cpp, and change the two dword values there. If you're using a disk image (likely for win98), you'll have to hack the serial in the disk image.
Reply 3 of 3, by wd
Rank DOSBox Author
DOSBox Author
If you can compile dosbox yourself, you can add some logging to what your
app checks (dos function 0x69, or the ioctl function ripsaw mentioned).
