keymapper probs with #
First post, by burny26
So ive just recently picked up C++ and i need to have all the keys at my disposal .
I have an azerty keyb ,so i typed keyb be to let dosbox acknowledge that im using an azerty ,which it confirms .
Than when ive finished adding the beginnerslines to start with C++ and i get the blue screen (ya im a noob 😁) and i try to type in # ,it registers nothing . I dont have the \ prob ,but the # prob . Ive tried keymapping but i only made it worse .🙁
Any suggestions ?
Reply 2 of 21, by burny26
it doesnt say a thing of pressing alt gr + key, only alt and ctrl
Reply 3 of 21, by robertmo
what is your dosbox version and where have you got it from?
what is your Operating System (and its language)?
what are your PC specifications?
post content of "DOSBox Status Window" (in Windows: right click on its title bar -> edit)
enclose your dosbox's config file
what is your keyboard layout and language?
what keyb setting do you use?
Reply 4 of 21, by burny26
-0.74 from http://www.bestsoftware4download.com/software … d-rqeabjvs.html
-win7 64bit dutch
-intel core i5 750
nvidia gtx 275
4gb RAM
config file :http://www.filefront.com/16777207/DOSBox%200. … 4%20Options.bat
-keyb layout azerty , dutch
-belgian point
Reply 5 of 21, by robertmo
get latest dosbox from www.dosbox.com
Reply 6 of 21, by burny26
have it already ,am using 0.74
Reply 7 of 21, by robertmo
but get if from www.dosbox.com and remove the one you have
Reply 8 of 21, by burny26
it uses the same mirror
Reply 10 of 21, by burny26
keyb be , bnecause i use a belgian( comma)
Reply 11 of 21, by robertmo
you mean the keyboard doesn't work properly everywhere or only in C++ ?
Reply 12 of 21, by burny26
in Dosbox,cant work in C++. C++ is the language
Reply 13 of 21, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Does the #-key work in the DOSBox command prompt?
1+1=10
Reply 14 of 21, by burny26
it works in the black window but not in the tc/blue window. The blue window i get after inserting the proper commands .(noob at work ,not familiarised with the names )
Reply 15 of 21, by burny26
do you understand ?
Reply 16 of 21, by burny26
the thing is that when using keymapper . Im unable to select # . whenever ichoose the key where it is on . I get 3 or " . How can i map it so it chooses # ?
Reply 17 of 21, by wd
Rank DOSBox Author
DOSBox Author
You can't. The mapper remaps physical keys.
Reply 18 of 21, by burny26
so im unable to use # ?that is weird 😁 what can i do than ?btw with the physical key you mean the one i get when i just type it ,like the t when i type t and the one i get when i press shift ,being T ?No alt gr situations ?
Reply 19 of 21, by Qbix
Rank DOSBox Author
DOSBox Author
map a key to 3
and press shift that key
Water flows down the stream
