LoadHigh
First post, by lemm
Hello, I am trying to load a TSR into upper memory by typing "loadhigh tsrmusic.com" on dosbox 0.74 compiled with --enable-debug option on linux.
I have set ems=false in my config file, and z:\mem reports 127kb free upper memory in 1 block, and 632 free conventional memory.
However, when I load the tsr using loadhigh, mem reports 127kb free in upper memory, and 620kb free in conventional memory, although I wanted the TSR in upper memory.
What am I doing wrong? Thanks for any help.
Reply 1 of 1, by ripsaw8080
Rank DOSBox Author
DOSBox Author
It doesn't work except in a specific case where the TSR is an .EXE file and its header indicates a memory requirement that fits into upper memory. Many .EXE files, and all .COM files, try to take all available memory, and therefore don't load high.
I reported the problem to the devs, but I'm sure it has low priority considering that games don't need the feature.
