First post, by StarSword
I'm running The Elder Scrolls II: Daggerfall on DOSbox, but I'm having trouble activating a cheat code. Invulnerability's code is Ctrl-F4, which according to the Wiki is used by DOSbox for something else.
I'm trying to use the keymapper to reassign the key combo, but the article on the Wiki doesn't explain how to reassign key combinations. I need some help.
StarSword
