Disable ctrl+F9 in dosbox
First post, by sepehroo
I've just installed dosbox and It works like a charm , but there is a problem, I use Turbo C for programming under dosbox and as you may know combination of ctrl+F9 in the IDE does the running of the compiled program , but Ctrl+F9 exits dosbox. how can I force dosbox to send Ctrl+F9 to Turbo C or disable it somehow so my TC IDE captures it.
thanks in advance
Reply 2 of 3, by vijaymanoha
install dos box
http://blog.bestsoftware4download.com/2010/02 … c-on-windows-7/
z:\>mount d c:\Turbo\
Drive D is mounted as a local directory c:\Turbo\
Z:\>d:
D:\>cd tc
D:\TC>cd bin
D:\TC\BIN>tc
click on ok
if any problem came with ctrl+F9
go to dos box
and press ctrl+F1
and it open keymapper
here you need to select shutdown botton
then it will indicate DEL press DEL
and save setting
