First post, by GermanAlex
On the same computer (XP SP3 x86) I open DosBox, run FoxPro 2.6. Open a DBF (with 200 or more records) in shared mode. Add a record, input some data, move up and down in the DBF. I open the same DBF in FoxPro with NTVDM. (normal mode) As long as I don’t close the DBF in Fox under DosBox the data written there is not committed, no matter what I do or how long I wait. FLUSH or UNLOCK won’t help either (in Fox under DosBox). My FOX program working on the network crashes every time it tries to even SCAN the DBF because there is some LOCK on the DBF. I need DosBox because a client has a computer with Windows 7 64Bit in the network and I have to run Fox on that computer. How can I solve this problem, please?
Reply 1 of 9, by wd
Rank DOSBox Author
DOSBox Author
This is not supposed to work.
Reply 2 of 9, by Jorpho
You could use a VNC client like TightVNC to access the desktop of one computer from the computer running Windows 7.
Reply 3 of 9, by GermanAlex
Does someone now where I can find a working VDH with DOS + network. I found DOS VHD + DOS Client + Network driver but I can’t figure why it doesn’t work. I used it a few years ago and it worked ok. I am not sure about the virtual network driver.
Reply 4 of 9, by Jorpho
You're not making any kind of sense. What does a DOS VHD have to do with anything!? Were you using this DOS VHD under XP a few years ago? Are you expecting it to work in DOSBox? How will this solve your problem? Details, details!
(By the way, DOSBox can mount hard drive images directly with the IMGMOUNT command.)
Reply 5 of 9, by GermanAlex
As you see above I can't use DosBox and FOX in the network. So I tried to use a VHD (virtual HDD) with DOS + Network, but I can't make it work (at least not in the virtual world). I used DOS + Fox in the network and I had no problem. That's why I am looking for a VHD with DOS and a working Network.
Reply 6 of 9, by wd
Rank DOSBox Author
DOSBox Author
How do you use a virtual HD? Are you talking about Virtual PC?
Reply 7 of 9, by GermanAlex
yes
Reply 8 of 9, by wd
Rank DOSBox Author
DOSBox Author
Ask microsoft or search their vpc pages whether they provide such VHDs.
Reply 9 of 9, by Gene Wirchenko
You might be out of luck. As I recall, FoxPro does some non-standard locking. It locks in the upper 2 GB of 4 GB corresponding to the actual bytes being locked. (This is so locked records can still be read.) That is why tables are limited to 2 GB. This may be causing problems with DOSBox.
You could use Visual FoxPro under Windows.
Sincerely,
Gene Wirchenko
